It’s the PERFECT FIT , I am showcasing the BRZ housing in the IS300 tailight for now , but the end result will be a OEM is300 housing with BRZ LEDS inside . Currently it’s all a test and so far so good but I’ll update you guys when I finish it
This is a LED board inside a IS300 red shroud , so as u can see trimming is needed but it fits nicely, my next concern is LED placement, as the center reflector shroud is bigger than the BRZ . my current IS300 red shroud is blacked out from the previous owner of this taillight but so far it looks like it will be a perfect fit which will look OEM
Wow so it does fit perfectly! That looks really good when lit up. Hopefully, the final product won't look so rough around the edges. Looks like you wouldn't need the IS300 red lens, and you wouldn't want to use it anyway, since it has "lines" in it that would distort the LEDs. Keep us posted!
That's incredible how well that fit in there, literally the same size and a direct replacement! Even keeps the reflector and matches the aftermarket trunk lights. Nicely done!
