1 - 11 of 11 Posts
I had a banging sound system in my IS350, and it caused my front left HID to start randomly going out. I have since removed the sound system, but that bulb stills craps out randomly. Could the bulb somehow loosen?, or do you think its damaged and I should buy a new one. Also, is it hard to get into where the bulb is.
/densone
/densone
Are the HIDs stock or aftermarket?
try swapping out the left and right ballasts.... keep the bulbs in the same place...
see if the problem can be reproduced after the swap
I suspect the ballast is going bad on you...
i'm a dealer or xtralights they might have a ballast but ck to see if there is a brown dark spot in the bulb tha may mean you have a bad one but just swicht the bulbs around to see if bulb is bad or the ballast. let me know and i'll get close to cost for ya.
thanks I will test this weekend.
shoudlnt it be under warranty still?
1 - 11 of 11 Posts
