1 - 9 of 9 Posts
Hi:
anyone know the spec for IS200/300 front fog light bulbs???
and what wattage?
cheers
SSML
Has anyone of u change aftermarket front "FOG" light?
r u sure it's 9006 (HB4)?
Is it hard to change front "FOG" light bulb? how?
thanks
SSML
SSML .. there is something called a Lexus manual that came with your car. It will tell you exactly which bulb you need, and yes it is a 9006 HB4. As for changing it, its pretty much useless to change it unless change the foglight housing to the JDM or the euro clear ones. I believe you access the bulb through the wheel wall, just pull that back and you should see it.
I'll give him the benefit of the doubt that his light might be broken...You;d have to go through the wheel well as if you were changing the bumper light (there is a faq on this...hint, hint...if you don't know how to do it) and it's right there. just an unplug and a twist.
Discussion Starter #8
Mine is IS200 withOUT HID head light, so foglights are not yellow like USA IS300 version.
I belive AUSTRALIAN spec is the same as JDM and euro spec.
thanks anyway
SSML
Threadlocker
thanks anyway
SSML
Look in the manual then, why ask the mostly USA forum?
1 - 9 of 9 Posts
