I took a peek today attempted install, and decided not to install my gauge
without further consolation..we have the 4 wire o2 sensor - which I was hoping we wouldnt..so my question is...
which of the 4 wires is the signal wire? -
I had assumed it was white - but i didnt recieve a signal off it - and I'm assuming black is signal ground and one of them is for a sensor heater or something - maybe the blue or brownish one..
unless theres a better method than tapping off the o2 sensor - i.e. off the ecu?
help a brutha out.
what up apoji? is that a wideband you have? If not, I think thats what you want (and you have to get a new sensor i believe), compared to a regular sensor that taps in. i heard the regular ones aren't too good.
Yea, I have a wideband.
I'll check into a new sensor - maybe one of those Hal-tuner o2 sensors.
maybe I'll get sassy one day and do things the way they should be done and get an egt gauge
so are you saying that if we wanted to install an autometer a/f gauge that we need another 02 sensor?
if you could, just please clear it up a little for me.. thanks
If you get the Autometer A/F gauge you don't need a new o2 sensor, but the capabilty of the gauge is very limited. It will only tell you if you are too lean or too rich... Not by how much. A 5 wire wideband o2 sensor and a display is the way to go.
apoji187 - An EGT gauge..."the way things should be done"(?) I tend to disagree with you on this one. Looking at your EGT gauge as a way to determine your A/F is a second rate option. This is much less accurate than a wideband. An EGT gauge is a nice thing to have, but a wideband will actually give you a real-time numerical read out of your A/F.
Hope this helps!
Kyle
