Crester said:
Could you shut off every other cylinder??? Like maybe have cylinders 2, 4, 6 shut off... and 1,3,5 running? That might help with the balance?
This is what I was thinking... but I was reading about the way GMC accomplish this and it sounds like their head is somewhat complicated, but I'm not sure if it is necessary.
The way theirs works:
"To switch the engine from 8 cylinder to 4 cylinder operation, the computer operates four solenoids that control oil flow to special hydraulic lifters for the intake and exhaust valves for cylinders number 1, 7 4 and 6."
...snip...
"Hydraulic oil pressure, supplied by the engine oil pump and controlled by computer-activated solenoids, is used to dislodge the locking pin and collapse the lifter, thus closing the valve. In reactivation mode, removing hydraulic pressure causes the locking pin to return to its latched position to restore the lifter's normal function. The computer stops valve operation for all four of the cylinders within one engine cycle or two revolutions of the crankshaft.
Synchronizing the throttle opening, fuel injector control and spark advance with the valve deactivation is the difficult part and GM has mastered the programming for this critical sequence. I could not tell when the engine was switching between 8 cylinder and 4 cylinder operation. There are no indicators on the GMC Envoy to indicate it has the DOD system nor any visual indication to the driver that the engine is running or 4 or 8 cylinders. I did notice that the average fuel economy readouts on the trip computer did keep improving as I was cruising or coasting. Sit at a stoplight or accelerate and economy decreased.
During start-up and idle, the Vortec V8 runs on all 8 cylinders for smooth operation. During acceleration, all 8 cylinders provide power but the system switches to 4 cylinder operation during light throttle cruise or deceleration. I hooked up a computer scan tool that GM technicians use for diagnostics and checked out the readings as the system switched. In a short 10 minute city drive route, the system switched between 8 and 4 cylinder operation over 40 times. The only way I could tell this was by looking at the computer data. There was no roughness, hesitations, r.p.m. changes or any other sign of the DOD system operation other than my scan tool readouts. "
I'm not sure if keeping the intake/exhaust valves from opening is necessary, this is my main concern. If it IS necessary, then I fear this will be a little to hard to design and make practical... but who knows maybe someone here who hasn't read this yet knows enough to school me on this =)
hope everyone is enjoying their sunday!
