I am trying to locate and add preouts to the stock amp of a 2002 Lexus LS430. Any help from the Mods and the members of this forum is greatly appreciated.
What I did: I have added subs (2- 10inch HX2 Fosgate power by a PPI 800 Watts) using a Line level Converter.
My problem: I am not getting very good signals for the amp, it's like there are distortion and i believed the signal is weak.
What I want: Is for someone to help me in locating the factory amp so I can try and add preout like I did with my IS300.
Please help!!!!!
where are you tapping into for the LLC. You really don't need to go with RCA's for a sub setup. Use the rear 6x9 speakers as your source for the LLC and you should be set. If you are getting a distorted sound it maybe because your levels are off. Try turning down the signal level on the LLC and see if that gives you a cleaner signal.
any exterior mods on your LS? wheels? I have seen a few nice ones with systems around phoenix...
