1 - 20 of 34 Posts
Hey,
Here is my story crusing down palmetto prk road, after the SFR meet last night (south florida racing) i was doing 60 in a 30mph, i didnt see the cop, i have a passport and blinder, passport went off LASER it went crazy, i didnt slow down, at the same time the blinder went off i steped off the gas, the cop was still LASERING me, i flew right past him he turned his gun off my blinder stop goign off, he dint pull out of his spot, he didnt give me a tickect, :) So the blindder laser jammer works:) THIS sums up that dectors will go off and there will nto be a cop around/false alarm. Mine has gone off with laser and not been pulled over but the blinder never went off before. So just slow down, but the laser jammer worked and i was so happy.:) :) the cost of it was like 250 + install :)
LexIS307 said:
Hey,
You need to work on your grammer...
Peter_Klim said:
LexIS307 said:
Hey,
grammar* =P
LexIS307 said:
Hey,
Does the blinder have 2 front uhm modules (i dunno what they're called)? If so, where are they mounted (pics)? I was thinkin bout getting the Escort ZR3. Also, how much was install?
well, i have a hard time typing, 50% of the time i speak spanish...so that with the garmmer, but ill try..:) sorry about that. Pics i have @ home on my home computer, il'll TRY to post them up later today. Yes, GJ they are two mods
yup blinder kicks butt. If you don't have one already add a 3v LED in parallel with the buzzer, that way you will have a visual warning in addition to the sound.
GJ said:
Peter_Klim said:
LexIS307 said:
Hey,
grammar* =P
At least I got my grammAr correct. ;)
Guru of Supercharged ISs
damn.... wut if i have the TRD/ Altezza/ Rmm type grill can this thing "see" thru that grill mesh...??
i see no other place to mount these really ...??
do thye have to be a specific HEIGHT off the ground...? or could they be put into the lower grill opening..??? i saw specs on their distance APART... but nothing on the HEIGHT...
edg
wouldn't work too well seeing through the grill, as there are several LED's in the unit that send out the signal so the grill will block some of them. It should be clear of any obstructions. As far as placemet it should be as close in height to the license plate and headlights as possible and bewteen the two. That is because the cops usually aim for the license plate or headlights since it is the most reflective surface. You could always cut the mesh grill to get it to fit. I had to trim my grill slighly with a file to get it to fit.
baadhabit said:
can somebody school me on the laws behind these jammers? i read somewhere that theyre illegal because they transmit a signal.
Jammers are not illegal because they trasmit signal. Both radar and laser jammers work on frequency not restricted by FCC. They are illegal in some states because they interfear with law inforcement.
Many, if not all, radar jammers are a waste of money, being ineffective against most radar guns out there.
Laser jammers is a different story. There seems to be a few on the market producing real results. I would recommend doing some research prior to buying one. Independent source, such as SpeedLabs is a good place to start.
Depending on a state, it may outlaw the use of a radar jammer (good thing too, considering their inefectiveness and inconsistent triggering of radar detectors around), but not necessarily a laser jammer.
I have previously used K40 Defuser Plus laser jammer. It has gotten me out of a tight situation once or twice. V1 has proven to be a solid investment, at times capable of giving a more than an adequate laser warning (*don't comment on this if you don't know what you're talking about*).
To answer your question, it depends on the state you drive in. Read the local laws on laser jammers.
If someone knows specific states that do restrict it, please chime in. I never heard of enfrorcement of such.
Anyone think mounting these Blinder units just below the top lip of the lower grill opening is a decent spot for them,... they would be at the same level as the bottom half of the license plate , but definitely lower than the headlights by a good amount...
say in the pic below.......at either end of the lower grill opening attached to the underside of the upper corner of the lower opening just inside the upper corners on either side of the license plate...??
edg
So let me get this right.... your detector went off, and you floored it? :roll:
What a d*psh*t. :lol:
I hope you get a ticket. :shame:
Discussion Starter #19
WTF...can you read english, i said i didnt slow down, i let off the gas, no where did it say an increase in speed.
1 - 20 of 34 Posts
