If you want to mount the ballist on the crash bar, then yea it will be much easier to install the hid's by removing the front bumper (so you can access the crash bar. If not just remove the plastic on the inside of the wheel wells and it is 2 10mm bolts. **Removing the bumper is very easy, it only takes about 10 minutes max** My advice is to get a buddy to help you remove the bumper and install your hid fogs. Also you might want to wetsand/polish them while you have them off. Good luck!
