I just did the fog mod..... very easy with the step by step. anyways, got it done (with the add a circuit) and I guess I didn't fully understand the mod. I thought that you could turn them off when you wanted. Is there a way to still use the fog switch? thanks for your help
you should still be able to control the fog lights with the stock switch with the mod done, check your wiring.
