Are you talking about the fog mod that makes your fogs run with the drls? Because I know for one thing, that is illegal to have your fogs on with your high beams on, thats why they switch off when you activate your high beams.
Guru of Supercharged ISs
no i want the Illegal kind o Mod.... :eek:
legally, it has to do with the number of "light bulbs" that are allowed to be " on" at any given time... i think it is 6..whatever.. .i do not want to run all day like that... but i would like to take advantage of my nice new HID fogs & also my high beams for those dark ass canyons i run nightly...
the Std Hid's & the HID Fogs are SWEET it 's just that the cutoff is a bit lower than I would like for fast running....
I dont think searching is the answer. He wants the different Fog Mod, not the common one that is posted like 100 times on here. By looking quickly at a the schmatics of the combination switch, it maybe possible to take the white/red wire and jump that to the black/white wire which would by-pass the rest of the combination switch and just have the fog switch as a stand alone switch. It looks like it will work, want to be the guinne pig? I will send you diagram if interested.
#10 is also #17 because it loops through and its a red with a white stripe, and the ground for it is #16 which is a black with a white stripe. Like I said, you should be able to just cut the wire at the #17 spot, not the nuber #10 spot, and tap it onto #16.
