I'm not sure if the fog lights are out or not but how can i check? i noticed that when i turn on the lights they don't come on anymore. and how would i be able to replace them? thanks in advance.
Do both of them not work? Are you sure the switch is in the position to turn the fog lights on? Well there are 2 10mm bolts on the side of the foglights that bolt it to the bumper, remove those. Then fog light slides right out. Undo the bulb in the back and check it for power or throw a new bulb in and see if it works.
Dont forget to remove the splash guard in the fender well. It will be the way to undo the plug thats connected behind the foglight. You would want to unplug it before pulling the fogs from the bumper.
