on the drivers side there is a little panel you remove on the splash shield.(under the front bumper) The passenger side is a little more difficult as you have to pull the fender liner back. Turn your steering wheel all the way to the left. Just unscrew the bottom two tabs and carefully pull the fender liner back. Be careful not to touch the new bulbs.
