1 - 20 of 35 Posts
chrisCARL0S said:
Yep. Just bake them, paint the housing, and reseal them. Just like headlights.
reseal them with silicone right?....this will be a good DIY tommorow
If done "correct" you may or may not need extra
So if you want to be safe just add some
And to smoke talking about the lenses or the housings?
Discussion Starter #7
paints housings black oops....edited
Its cool cause I was going to suggest smoked Xpel for the lenses if you were doing that
But yeah man get some paint and primer and get it done
Discussion Starter #9
got them open right now jay.....should i sand the silver gloss down a little to get the paint to stick better? or just primer it and paint it?
Yeah just rough it up some to give the primer to adhere to
Discussion Starter #13
thksdad said:
it looks good. i think ya need to clean the clear part though...looks like there lots of white specs on the clear part.
yea there a lil dirty + rep for the comment
Look good just wetsand the lens with 2000 grit sand paper. That grit would make it easy to polish when done. Just make sure all scrathes are off when done. Now find a good polishing compound and rubbing in and off till you get the look you want. not very hard but worth it. Good luck..
Reactions: linner420
Discussion Starter #15
thanks + rep i was wondering how I could get the plastic lens to look like it wasnt so used.......
ALso got any recommendations for a polishing compound?
I use 3m Polishing compound. Works great but you should be able to get away with others also.
That looks good but I have one question, what's the point of blacking out the reflective part around the lens? Won't that make them pretty much useless?
^^ Good point, but our fog lights are projectors, so the reflective housing really doesn't have a point except for looks. Projectors dont use reflective housings to refract the light.
1 - 20 of 35 Posts
