Looking to run stock 08 is250 18x8.5 wheels all around on a stock height 2002 is300sportcross with 225/40/18 in the front and 225/45/18 in the rear. Will i run into rubbing issues without having to roll fenders. Or could anyone point me into what size tires would fit without having to modify fenders. Thanks
Thanks. Upon reading decided to try the 8.5s all the way around with the tire sizes I mentioned. It was a no go. 18x8.5 in the front with a 45 offset and 225/40/18s did not clear at all so back to 18x8 in front. I'm trying to put bigger wheels with similar tire size to 17" wheel. With just have to keep staggered wheel setup
I'm trying to drift a IS300. It's lowered 2 inches, and has fenders that are +40mm in the front and +50mm in the rear. My suspension is TEIN Street Basis Z Coilovers for a 2001-05 is300. The number is GSY20-81SS2. Quite simply, my problem is that I have no clue as what to do for wheels. What are your guys' recommendations?
Read a bit.
Wheels and Tires
