1 - 2 of 2 Posts
2001 Lexus IS300
I’m very new to the wheels and tires scene so please bear with me. I was wondering if I could get some help or tips and see if this set up will fit without rolling any fenders. I found some Enkei TS10 rims. The specs are:
18 x 8.5
Bolt pattern: 5 x 114.3
Offset: +35mm
My first question is will these rims fit correctly for both front and back? My second question is can I put on tires that are 245/40/18 on the rims and still have proper clearance? Note that my car is still sitting on stock suspension. I’m saving up for a good set of coilovers eventually. And also any tips for how to pick the correct hub-centric rings?
There are treads that show fitment stuff if you search and read. As for the tire. It is too big for the front.
1 - 2 of 2 Posts
