1 - 9 of 9 Posts
· Registered
My first tank of fuel finally ran low when I hit 300miles. I had to add 15.73 gallons to get back to full which works out to 19MPG.
Pretty lame considering I am going super easy on the car (staying under 4K RPMs) and doing alot of 60-70MPH freeway driving...
Hopefully the mileage will improve as the car gets some more miles on it.
· Registered
Like I said once before, this car does not get the best mileage when you baby it. I tried so many technique, and so far I find that you have to mix both easy and semi-aggressive driving to get the best mileage. The best I have gotten is near 21mpg, and the worse is when I first got the car which resulted around 18mpg. Also, I do think that IS burns alot more gas when in idle, and that may explain why your mileage just drop like a rock after being through a 10 minute traffic jam.
· Registered
MPG will not improve. Mine has gotten worse, most likely because now I am over with the break in I am having a lot more fun with the car.
Like I have said before. MPG is not a big deal for me. If it was, I would have never purchased this veh.
· Registered
Mine actually got better. Doing mostly freeway travelling, averaged 24-25. However, I got a new job and never drive on freeways (so nice to work a couple of miles away from home!!) and now I'm getting about 21 driving backstreets to work.
· Registered
19 is pretty good for a break-in mileage. My commute is basically local. I'm on the freeway for about 2 miles and then 6 miles of local roads. My first fill up was 16.5 mpg. Now, I'm doing about 18-19. I'm sure I can get this up to 22-23 if I were to do mostly freeway driving.
--k
1 - 9 of 9 Posts
