Finished - Throttle Body DBW to slave DBC with OEM function - TEST DRIVE and VIDEO!
36K views 73 replies 19 participants last post by  Drutort
#1 · (Edited)
What I hope this project will bring to the table when it is finished, similar results to what we have seen in the 80mm TB swaps fabs. But with these possibilities below:
  • Placement of your own Cable driven TB wherever you want
  • With the above this gives the user the possibilities of Dual TB's and ITB's (Individual throttle bodies)
  • The possibility to tweak the linkage cam (RED part in pics) (lobe) to advance, slow/speed up the throttle body butterfly opening
  • The slave linkage cam will be replaceable in the future based on users needs
  • Full OEM function (cruise, traction control) should be retained, as all the sensors and main components are still present
  • Will require to do throttle body coolant delete/bypass, and extending sensor cables
  • Launch control should still function
*This project is geared to retain OEM functionality, because of this it will require an OEM TB donor
This is for the mechanical guts transplant, this will keep my costs down. I believe the disassembly is pretty straight foreword anyone with some mechanical knowledge and proper tools could disassemble the OEM TB
I will give a little teaser of current progress.
Reverse Engineering of OEM TB system almost complete, main section as can been seen in pics below is done, CAD model pretty much complete, soon to come prototype and test fit of OEM components to see if all fits, few custom parts will have to be made.
Then of course a cable cam and a slave DBC TB :) of your choice :D
=== update 8/29/2013 ===
For those who could not visually see what was described, I added mock up pictures showing quick mockup CAD files of the other components
you can see that on the right side of the pictures the regular driver cable goes to, the center CAM cable goes to a slave TB :cool:
=== update 9/5/2013 ===
I decided to put up some pics of the work that had to go into reverse engineering the TB for this project, what you see is 3 pics of an is300 TB machined a number of times to allow for dimensions to be obtained for CAD model.
Initially I was going to use these parts to make my own kit, I still can, but I found out that its easier to machine and have everything match up perfectly and reduce some parts that are not needed for the function since this is not a full TB anymore, also a fully machined block can have some space savings which is quite critical for the installation of this unit in the engine bay.
=== update 9/6/2013===
small update went and took better measurements of the actual parts, before it was just quick visual mockup, now the lengths are pretty close. The overall length from tip of one side (plastic motor/actuator) to the OEM throttle cable cam-flat part is 10.6in long, I know I can shave 1.1 inches currently, so that is 9.5 inch unit, that is much more slimmer then OEM.
I measured the OEM throttle body length and its at 11.5in +-.25in, the throttle body cable to the firewall is about 6-7in depending at what height you measure it.
So I figure that few inches shaved by simply angling my unit will keep me at the OEM throttle body cable position, this way not having to mess with it much. I will have to get creative on a mounting system for the unit, I do not think I will mount it to the intake system, most likely to the engine cover or something near by? otherwise a standard will have to be devised if going to intake system? Any ideas?
The way I am going about installing this unit is 180 deg flipped of OEM throttle body, so were you see the black cover on your car its flipped on other side to the firewall.
=== 9/20/2013 ===
Had a bit more time to play with the model, had chance to pull some rough dim from the Petal Position Sensor (PPS) side of the TB housing. I believe the best OAL (Over all length) will be 9.75"
=== 9/27/2013 ===
While working on the model, and setting up program for the main housing, I started to do research about the slave throttle body cable that I would need.
For more details: Post #22
=== 10/5/2013 ===
Today Managed to get some time to finish up the CAM file and generate CNC g-code for the main housing. Was able to put in a bit of work and I am very happy with the results, aside from some machining/tooling issues the housing was completed.
The very first thing of course I went to do a test fit, as you can see in the pics, I put the OEM parts into this new machined housing, it was quite exiting to prove out my reverse engineering, which in itself was quite a challenge, dealing with a casting. It was nice to be able to have it done on the first try, I have to say I was a bit skeptical myself, as I know the small changes that had to be done from CAD to CAM to make it work. Then having to go and machine it was a complete different story, and whole ball of issues challenges in itself.
I will start to put photobucket or other picture sharing site, as I won’t be able to put all of the pictures, at least not in this main thread. I recorded a small video with my phone in one hand and rotating the housing unit with the other as best as I could.
Next up, will be CAMing the 2ndary housing and the bracket.
For more details: Post #23
Housing assembled and being tested for fit and function - YouTube
=== 10/12/2013 ===
So I had a chance to put in sometime into the project. Finished up 2ndary housing CAMing, and had time to setup and machine it!
Next up will be the mounting bracket.
For more details and pics: Post #29
=== 10/23/2013 ===
Been busy this week, but managed to finish both housings! and the bracket, I managed to have the shaft split, and even the CAM machined, though not done.
So I got to test fit the main assembly, it all works good, did not get a chance to put the gears but I did that already in other thread. I still have to finish the CAM and the shaft.
Once those are done and I get more dimensions from the test parts I will make adjustments and improvements, but everything should still be functional in current state.
I had a chance to through the whole unit into my engine bay, sorry that its pretty dirty and pics taken with phone at night.
I will throw a few ideas for placement, though real testing will be done when I have chance to take off OEM TB and y-pipe, then Ill have more pics!
For more details and pics: Post #39
=== 10/26/2013 === MAIN UNIT COMPLETE
Had chance to work on the project a bit, and worked on the CAM and shaft. Both are now finished and are the last main components.
Next up will be brackets for the OEM throttle cable and the slave CAM, as well as thoughts on mounting the whole unit in the engine bay.
Once the brackets are done and mounted I will assemble everything like OEM, I have done partial installations of the guts for all the processes/test fits. Soon though it will be a final install.
Afterwords will put it on the car and disconnect stock OEM TB electronics and sensors, leave the TB alone, connect a CAM on the OEM TB and connect the cable from this unit. Then test things out!
=== 11/11/2013 === MOCK TEST FITTING
This weekend I decided I could find some time for this project. I figured that I could do the mock test fitting in my garage. So I apologize for the hmm cheap improvised mock up for installation.
Took some time to take off my intake and TB, then jumped right ahead to removing some of my OEM TB parts. Once that was done I put the OEM TB stuff on my unit and went ahead trying to find a home for it under the hood.
After some time, I felt pretty defeated, every place I placed that seemed to have room I was short on room just a few inches or something was bulging out at some place and caused interference with the unit.
I finally realized and had to come to a compromise.
BAD news is there is but only 1 way to put this unit with only 1 type of setup that would allow for full plugin play, all other ways require a new extended throttle cable. Which was a bummer as I was really counting on placing the unit in such a way that you could get away with using the OEM throttle cable.
Good news if I plan on going FFIM all I would have to do is placing this unit right were the stock unit was and all the cables and throttle cable would work.
The other good news is that if your not going FFIM but with a larger TB and Y pipe, and keeping similar to stock intake configuration then I did manage to find a spot for the unit. You can see in the pics the mock up cardboard stand and copper wire holding the stock throttle bracket, and before anyone asks yes the hood does close!
As far as brackets are going, im sticking with the OEM one for the OEM side and making my own for the slave CAM side. I still need to make a bracket for the OEM cable bracket? haha if you can call that :p
As for the OEM cable replacement I would guess anything over 35in would work? as stock is 19-20in long.
For more details and pics: Post #47
=== 12/24/2013 === TEST DRIVE!
I'll come back and add more details, its been quite the ride with a lot of small changes back and forth on a number of area's. I finally did find an aftermarket throttle cable that is long enough for this setup and comes almost close to OEM fitting at the firewall, just need to cut plastic part a bit to open up, and use OEM rubber gourmet instead of the aftermarket one.
I finally went with the idea of using standoffs of off the valve cover screws and the engine cover stud, the forth point is just a standoff under tension from the others.
Had major issues with the slave throttle cable, at the end I ended up making new support plate that holes the whole setup on those standoffs, and new bracket to face the cable in reverse then what I wanted.
The OEM throttle body is used for testing this whole concept, as you can see no sensors or motors are on the OEM TB, which acts as a regular DBW TB, only cable and CAM connected directly to the butterfly shaft.
Adjusting the set screw and the TPS sensor is a major pain, because I also have to adjust for the DBC TB, idle at cold and warm can be problematic, I will have it all dialed in, then start it up and get the trac light flashing and CEL, going directly into limp mode. I am still learning all of this. Though I wish I did not mess with it because almost on the first attempt I had it running nice, ya it idled a little low but was ok over all.
Had to extend all (3) the sensors and motor cables as can be seen, that was quite the fun…
It is very interesting to watch the ECU control the TB, the video shows the delay that everyone is talking about, also tried the ECS and Snow buttons, but those do more when car is in gear rather then parked without load.
I will still be testing it for a bit, and also probably come up with a support bracket that fits were the OEM TB is, for a FFIM setup?
For more details and pics: Post #51
IS300 Throttle Body DBW to Slave DBC - YouTube
=== 6/3/2014 === Throttle Cable
Just a small share of discovery, that is that the OEM GS/LS 400 VVT-i 98-00 throttle cable works as a perfect direct bolt on for this, its more then long enough, and the quality of OEM throttle cable vs the aftermarket (some random toyota vehicle fit) is noticeable and there is a lot of room for the bend which what is needed for a U
See less See more
10
#3 ·
Pretty much the ecu should see it as the regular TB, this is taking the butterfly and placing a cam with a cable connected to an identical cam and cable on a standard dbc TB
This will allow for larger TB, dual TB setup and hopefully an ITB setup :bigSmile:
#4 ·
This would be sweet for sure
#6 ·
see, if this could lead to the development of a functional ITB setup, I would 100% all over that.
#8 ·
Ok I think I get it a little better now... I see how the stock DBW motor assembly could be used to drive a larger throttle body/plate... which is good if you want to move to a larger throttle and keep the DBW system.
I don't see how this would improve the overall feel/response of the laggy DBW system tho. If the motor is still in there actuating the plate, it won't be any faster reacting than before... or maybe I'm missing something still. I'll wait to see more...
#9 · (Edited)
Personally I do not think we can ever change some features of the system when we are tied to the ECU, now maybe with a piggy we can change few things, or we could try and create a non linear CAM that would speed up the response possibly a bit, but honestly there is no way to change it without fighting the ECU and from what I read if you fight the ECU you will throw codes.
I believe we can work with the system as it is, if we can tweak it a little in some area's then it would be an improvement, now going dual TB and moving the TB closer and or going ITB alone is worth it, and will change the overall throttlebody response.
I learned from the people who did the 80mm TB that they got quite a bit more of a response and they used OEM parts, so this should work with the setup that I am going with.
I think I can make a CAM that is nice and linear for the first say 25-50% of opening and then speed it up a bit on the other 50-100% that way even if the ECU controls the rest of it, it will physically move faster the rest of the control.
Now how much can that be tweaked or worked out? before a CEL or some other strange behavior? that is all to be tested and determined, nobody has messed with the TB this much, and honestly I will need the whole community's input, collaboration, insite etc...
I am willing (given the time) to take this project and turn it into a product eventually... :)
--- my rant----
here is my guess. The only way to work with the ECU is to fool it into thinking or giving it what it wants, with that said, I believe some slight tweaking on the mechanical side can be done, but anything else should be with some logic circuit that would piggy specifically with the sensors and the servo motor signals in the TB assembly; I believe that would be the ultimate TB response upgrade, and even then the ECU might have expectations that can not be exceeded otherwise it might through CEL.
I would guess the logic system would intercept the TPS sensor positions, and be able to decoded the ECU's signals to and from the TPS and the servo motor controlling the butterfly, so this logic circuit would need to mess directly with the servo motor to accelerate in a faster fashion then the ecu and yet send the right info to the ECU for it to be happy. Otherwise the ECU its self would need to be hacked and that is pretty much null point IMO.
I have read few forums were people did a DBC mod, and the ECU eventually was not happy not to mention you would probably fry the servo motor, or it would slip. Honestly having taken the whole thing apart the ECU still wins unless you mechanically force and mod the internals, which I think is never a good idea, and the other kit that we see is doing something like that.
#10 ·
#11 ·
Yes I have seen it :)
I am a mechanical/MFG Eng, im not an EE, so some of the info they might have pertaining to electrical is above my head, I know how to trouble shoot stuff and solder as far as electrical goes ;)
I have a much bigger project that will be revealed when its done and tested, its a grand project thats all I will say ;) Though related to this in a way :)
#13 ·
Cool CAD drawings... I'll be watching this lol
#14 ·
I uploaded pics of a real is300 TB that was machined down, in order to get the dimensions and data needed for CAD model generating. :cool:
#15 ·
Very nice idea. Only way I would be happy is to get rid of DBW with auto. If that can be done, I would pay decent price for it. Otherwise there are other options for bigger TB. I will be running 75MM GTE VVTI TB on my FFIM on my setup. I wish I could run any TB and not worry it with auto. Space is one of the biggest issue in IS engine bay.
#16 ·
This will give option of what I call slave DBC TB. All the mechanical and electrical stuff is used from OEM, plus or minus a few parts ;)
After this kit is done and similar size aftermarket TB is tested, I will try and see how dual TB for NA purposes would work right at the end of stock y pipe, not sure on sizes? keep it at 60mm or 50mm?
with dual TB's the velocities should be much better then one single large TB? though of course its not that simple (we are talking NA, not boosted)
#18 · (Edited)
Cost is hard to say, I have what you see on the front thread, I havent done a prototype yet, also the machining is one thing, then the assembly or the transplant of the OEM parts into this new housing will add labor too, I have no idea those costs yet.
See my other thread for an idea on cost, those are rough guesses though.:suspiciou
#19 ·
small update: updated asm and got shaft calculations for split
I got a chance to work on this project a bit more, I updated the model so that people can clearly see more details, the linkage slave cam is now in RED, this will drive your slave drive by cable TB :) This cam can be tweaked, the geometry/lobe can be modified according to the users needs, depending on what TB or setup is being used. I believe its possible to tweak this, of course watching your A/F as the ECU will think everything is fine, but we can mess with the mechanical parts now ;)
Also I am happy that no shaft will have to be made, at least by the calculations that I have its possible to remove the butterfly valve and split the shaft, join it with a small wedge that is same thickness as the butterfly shaft and shove it between the split shaft, this would be a safety in case the set screws get lose in some unpredictable situation :jawDrop:
The project is getting more detailed and closer and closer to the prototype phase :cool:
#20 ·
Nice update with the pics.. looking at the concept more, I was curious do you think the stock motor assembly will have enough torque to pull another throttle plate with its own spring? I mean, the place where you have the cam attached is where the throttle plate used to sit, and it does not have an additional spring there stock. So to pull on another cable throttle with its own spring might put extra strain on the motor / clutch?
#21 · (Edited)
That is a good point, I believe it should be fine, but you are right about spring, the TB whatever is being used as the slave TB must have a spring of its own as well, I think the motor is plenty strong, if it lasted well for most people who did the crazy mod by forcing the 45 degree of there Throttle Position Sensor (TPS), which pretty much made the motor fight against the users foot all the time.
Also I have messed with the whole system and springs are pretty strong even in normal working conditions, so under normal conditions the motor has to move the butterfly constantly with all those spring forces acting continuously.
This point also brings me to the search of throttle cables, I guess it would be very important to minimize any restriction or resistance so that the whole OEM system can operate properly.
The biggest issue will come to ITB setups, were proper spring loading will come into play
#22 · (Edited)
Slave Throttle cable - search
So I am looking at linking cable or as it should be called slave throttle cable.
I do not want to make my own throttle cable so I am looking for OEM or OEM like replacement parts that would fit the bill.
I started to look at quad and dirt bikes. I noticed that the front brake would be good length.
I purchased one Motion Pro 02-0167 Black Vinyl Front Brake Cable : Amazon.com : Automotive
not bad for under $15
Thats another point, the price needs to be low probably under $20
The cable must be exposed enough and the ends need to be barrel type.
Needless to say, that cable does not have enough travel, maybe 2 to 3 inches? Biggest issue was its too stiff!! the dia on the cable is way too much for throttle body cable.
SO that one is being returned.
I decided that I need to take a different route. I thought that a clutch or other cars throttle cable would be better option, but the length has to be much shorter than typical throttle cable.
So i search all ebay for cruise control cables! I remembered looking at ES300 and it had relatively short cable and also would fit the bill on the travel (for each end) of the cable, as this one is used on throttle cams on both ends!
example I found was OEM ES300 94
Lexus ES 300 ES300 Cruise Control Cable 94 1994 | eBay
I will give this a try now.
I need help from everyone for other alternatives, preferably a cable that can be ordered from aftermarket place the meets or exceeds OEM quality.
So far few other makes seem like they would work, please add any other finds.
Civic 92-95 SI hatchback
92 95 Civic SI Hatchback 37 Cruise Control Cable | eBay
92-96 Prelude
93 92 96 Prelude 142 Cruise Control Cable | eBay
Acura Integra 94 01
94 01 Acura Integra GSR 138 Cruise Control Cable | eBay
Honda 2004 2005 S2000
2004 2005 Honda S2000 AP2 Factory Cruise Control Throttle Cable F22C | eBay
Does not have to be car cable, but one that is thin as our stock throttle cable or a little thinner is fine
#23 · (Edited)
Machined the main housing! and test fit!
I updated the main thread with details on the success of the main housing on the first run!
You see the first pic shows the part in the machine still.
next pic is me test fitting the motor on it! Fits perfect, almost too tight, but thats a small change can be done.
Next came the plastic housing over the motor and the outside profile.
Then I finally went and assembled the OEM internals into the housing.
Other two pics show again the mounting of the motor and plastic cover along with the senor, all fits and works!
The video shows me moving the butterfly shaft. The shaft that will have the new slave CAM for the cable that goes to slave DBC TB
Next up when I get some time is the 2ndary housing and the bracket!
Here are few more pics
YouTube video:
Video of the main housing test with the gearing and servo motor attached
Sorry that the video looks all wavy, I was using googles auto shake remover, and at least you can see it without much shaking, though its all wavy and giggly looking LOL
#25 ·
Before this gets any more out of hand , there is no pricing or selling on this site unless OP wants to become a vendor ! Please clean up the threads of all this pricing and kit talk with intentions to sell etc ...
Op you have any questions feel free to PM me.
Thxs
#28 ·
Trust me, I am learning things too ;)
I finally got a nicer rougher tool and ran a 2nd one, I was hoping for much faster cycle time, but this part doesnt look that complex at first, but the configuration/profile really screws you over with such small clearance and such deep pocket, of course I have modified my model once again and it machined nicely.
I will revisit the main housing model once I finish the whole project, stair at it for a while and hope some ideas to remove or add few things will come ;)
Been busy, this week and weekend looks packed already and I have yet to do the other ops on this main housing.
#29 · (Edited)
2ndary housing machined
Made some progress this week.
Had some time so I finished programming the 2nd housing :) and got sometime to machine it!
things are moving along nicely so far
pictures below:
#30 ·
Looking good!
Just a question; why are you doing the cable side as well? You will need the TPS connected to the actual butterfly and cable to get the correct reading of the actual butterfly. Or am I missing something?
I hope you don't take my questions the wrong way, I'm not trying to be picky. I'm a mechanical engineer as well so it's an interest seeing how things work, most of my day is troubleshooting through design issues. ;)
Sent from AutoGuide.com Free App
#33 ·
This already exists and has been covered in depth with the 80mm DIY, you get the other TB's that plugin with our senors, but require extending the wires, cables brackets, custom mod of y-pipe etc...
To me personally this will not be cost effective and will probably be too complex and possibly exceed the requirements capability of the machines/equipment that I have access to.
Just take a look at the OEM TB housing now try to imagine to have to machine everything, the cast is much more economical, imagine trying to do that from solid block of aluminum, then trying to increase the overall diameter to 80 or 90mm
It might be possible to break down the cast design into smaller segments like I have done so with my design, but then you risk the issues with leak/sealing and with true position issues (things lining up perfectly)
#36 ·
any new updates yet?
#39 · (Edited)
Detailed pics of near completion of the unit
Ok, here is the update, main and 2ndary housing have been finished along with the joining bracket. Slave CAM has been mostly done few more ops left. The shaft has been split, still needs testing for securing it in the CAM. Few other small things left to do but here are the pics so far.
The 2 pics below roughly shows you how this unit stacks up against the OEM TB.
Here is my original idea of placing the unit in the IS300 engine bay. As you can see I am planning to have it sink into the crack were the spark plugs go with the servo motor end going to the firewall. Of course once its in its place it will move a lot more probably 2-3 inches in.
The next position would be to flip it right to the left, and place it, but this could require to extend the throttle body cable from the original position.
The OEM CAM has 2 areas for the cable and L and R and this works nicely, letting you flip the unit and still have the cable function right.
Another idea is to move it even more to the left, were it hangs off to the left allowing the servo motor part that sticks out to fit next to the valve cover
So there you have it, things are going well.
#40 ·
Finished shaft and CAM!
So I finished up the CAM and shaft, here is a pic of the used ES300 cruise control cable through the slave CAM, our OEM ones are about same spec.
Next up will be brackets for both the OEM throttle cable and the slave CAM cable.
Once that is done. I will be moving the unit into the engine bay, taking off my OEM's throttle body sensors and motor, pretty much turning my OEM TB into DBC throttle body for testing purposes.
I figured its best to test with OEM and how car is running now then trying to jump onto a new TB and possibly needing a tune. This would bring too many variables. Once the car has been tested and runs good with this unit using the OEM TB as a slave DBC TB then im all good for whatever TB I want :)
#41 ·
^ good lord man! I've been keeping quiet on this thread because I've been waiting for this... you, sir, are about to change our world!
unfortunately, I won't need this but I'm still stoked to see such ingenuity and effort put towards our car. I hope everyone will appreciate what a benefit this will be!!! most IS owners need this but might not know it yet :lol:
#42 ·
Keep up the good work, that quality and finish looks fantastic!
#44 ·
Cant wait to see finished product
#45 · (Edited)
thanks guys.
I can't wait when its going to be done as well!
I think this idea has been cooking for more then a year! (Probably longer since my interest in throttle body mods can be traced by the replies in some of the threads a few years back)
Samsung s3 AutoGuide app
