81 - 96 of 96 Posts
Discussion Starter #81
Well I just looked up the ring gap on the CP website and looks like I have some more filing to do. Min .018 for turbo applications. Back to it this evening...
Discussion Starter #82
Tonight I regapped the rings to cp specs and cleaned all of the old assembly lube off of the rod bearings. Pistons will go in tomorrow and hopefully I will have time to assemble the head. Pics tomorrow.
Discussion Starter #83
Progress is slow because I am super busy but there is progress. Piston and rods are in. Rear main seal and oil pump are on. Oil pan #1 is on. Hopefully o will get a chance to visit a shop tomorrow and talk to them about timing options. I can say that I contacted ProEFi for some options on shops to tune in my area and they have been very helpful. They even reached out to the shop to start the dialogue.
Discussion Starter #84
Work is still going on although at a slow pace. I have the bottom end finished. Now on to the head. I decided to go with ID1300x injectors and a walbro helcat 525 pump. Those should be here soon. I am still going back and forth on the transmission between cd009 and t56. Anyone with experience with the cd009 swap want to chime in? I am all ears.
T56 hands down. Choice in gears and strong.
Discussion Starter #87
Between CD009 and T56, I think the T56 is a no-brainer. There's a current thread going where I pontificate my opinions quite strongly: https://www.my.is/forums/f114/r154-cd009-600hp-need-help-607085/.
In case you missed this before...
I didn't miss it. I read that thread to the end. I am trying to get experience from those who have the CD009 specifically. There is a 2k price difference between the two with 🍎 2 🍎. I don't have an unlimited budget so was looking for personal experiences. I know we have talked about the T56. I am just trying to figure out what is going to be best for my application and budget. 2k is a lot to me especially considering I was going to go r154...
Discussion Starter #88
Received the 525 hellcat pump and ID1300x injectors. Just ordered the T56 transmission swap this morning...hopefully I will have some time to put the top end of the motor together this week. Taking the turbo manifolds in to get ceramic coated Friday. Moving right along.
Discussion Starter #89
Haven't been working on the car much lately due to "Life". However I have been spending money...lol.... Work will begin again soon...
Yes, yes you have spent some serious money!
I dont think the hellcat pump will fit the stock sending unit...what trickery do you have planned? It will be a good pump if you can get it to fit.
I’m working on getting a billet sending unit from an Evo to fit the IS300. Hopefully not much to it, plug off the Mitsu ports for the siphon pump since it’s all inside on a Toyota. The top hat is like 3/32 too big diameter, so it’s going to go in a lathe. Hope to test fit it soon, though, and not be a 400$ mistake!!!
Discussion Starter #91
I was planning on taking a look to see what modifications would be needed to get it to fit with the stock hanger. Otherwise I may just end up getting a dual hanger and going from there. I like what you have going on with your Evo hanger though.
Discussion Starter #92
Turtle moves over here...lol. The motor is basically done. I put some old cam covers on it to keep my pretty ones pretty. I am currently rebuilding the power steering pump. Once that is done it is on to the clutch.
Looking good, and getting closer. Nothing good happens fast at this stage.
May I recommend a billet timing belt pulley bracket, while you have the motor out? The billet steel PHR with the bronze bushing and hardened steel seat is a good one. May as well get a better crank damper too.
I like your anodized VVTi pulley. Never seen that done before. My Evo hanger is working great so far. No leaks and measuring fuel consumption like stock. You could probably fit a hellcat on the Evo hanger. Otherwise, you’ll have to mod a stock hanger. The base of the walbros where it swells out makes it harder to fit. If you could find an IS300 SRT or Squash hanger I think they’d work with a hellcat pump, too.
I see the Mcloud clutch box in the pic, did you get a twin disc?
Discussion Starter #94
I do have a billet pulley bracket from Brangers racing. The clutch is the RXT twin. I contacted squash an they said that their hanger is a few weeks out from being in stock. I will figure out what route to go when I get to that point. Thanks on the pulley I had it painted. We will see how well it stands up. What I am really trying to decide on is my throttle body situation. I don’t know if I want to go with the aristo type set up or go manual throttle body.
Discussion Starter #95
Clutch is on. The bread trick worked to get the pilot bearing out. Clutch went on easy. Throw out bearing and mounting up the transmission next. After that I will figure out my fueling scenario.
Discussion Starter #96
Progress is being made. More items have come in:).
81 - 96 of 96 Posts
