1 - 9 of 9 Posts
THE MAKER
these look promising, but will there be a version with the subframe mounts any time soon?
Still interested in the "hybrid" setup you talked about awhile ago on facebook :)
THE MAKER
Discussion Starter #5 (Edited)
After seeing how the 100 duro presses in, I will not continue to pursue the aluminum version. These are nearly the same modulus.
subframe insert bushings will be further tested as I have only had the car out once since the swap due to weather. All I can say is that IS520 is now utterly ridiculous with the recent changes.
Does this eliminate the clunk under shifting? Or which bushings do you offer that do assist in that?
1 - 9 of 9 Posts
