1 - 20 of 53 Posts
That thing is diesel! Very nice!!!!
Reactions: ItalynStylion
Nice, I need a new amp also. My JL 300/4 fail on me =[
It has a bad RCA output. It has some unclear noise in cold weather, but the problem will gone in 5 - 10 mins after I started my car.
looks great, I can't wait to see it installed.
Damn u. U made me get one too! So broke .....
\/ Awesome \/
Damn bro that sucks...is it covered under warranty? It's at least worth giving JL a shout.
Now we're blood brothers :lol:
After I get out of Organizational Management today the GF and I are going home to build a quick amp rack for it and install it. Initially, I'm just going to hook up the Focals to channels 1and2 which will send 100RMS to each set. I'm going to parallel all 4 Tang Band subs to 1ohm so I can get 600RMS from the sub channel. I think the subs are going to have a field day with it. Before they were getting 75RMS each but now they will be getting double that :cool:
that should be a good idea. it's going to take some re-wiring to get them active and 100 watts to each driver is quite a lot (unless are the drivers individually 8 ohms?).
\/ Awesome \/
Discussion Starter · #13 ·
Exactly what my thinking was. I need to buy myself a volt meter....yep I admit it, I don't own one :blush:
When I pick one up I'll test the resistance of each driver. It's more tuning than I can get done in a few days anyways so it's just not going to happen. There is an SQ comp on Sunday so I just want to get it operational.
Damn nice piece of equipment. Good luck with the install.
Can you point me to some pics of your current setup?
\/ Awesome \/
See the sig for current setup specs....the PPI amp is for sale actually
Here are some pics of the setup...
(clear pic of the amp before the subs went in)
Nice. I have seen these before, I just didn't make the correlation that it was your setup. I take it the white down tube is more of a stand to work around the "trunk hump" and not a port of some kind since your sig says sealed enclosure. Does a sealed enclosure or would a ported work better in the trunk? Congratulations on your wins.
Man, your gf is so supportive! You luck dog!
\/ Awesome \/
That white foam cylinder is actually a thing I use to stretch before running. It put it there just so it doesn't roll around in the trunk and make noise. It just happened to be the perfect fit for that spot.
Both work well in a trunk but a ported enclosure is louder than a sealed enclosure...wherever it is
gotcha, I thought it was part of the setup by the way the pic was snapped.
I guess I have always had better luck with the ported but it may have been the build of the box that I was using and the airspace needed.
ItalynStylion are you running rear speakers in your setup?
I want to upgrade my speakers this spring, wondering if I can avoid doing the rears since it probably will be a pain in the ass a little.
If I just did the fronts and a sub I could grab a small 4 chan amp that would fit nicely in the trunk. I want to mount it on the back of the trunk but not cover the ski pass since I ski :)
I want to keep trunk space, SQ is more important than volume.
1 - 20 of 53 Posts
