Some Help
Had it for 2 weeks already installed, in my taste its still kinda stiff not the stock ride I had, maybe out of 100% stock feel it was reduced to 75%, I trimmed the front bump stops since shocks are shorter to allow more suspension travel. It improved the ride I bit but still stiff. What can I do before replacing them. Wait a little while to allow the shocks and springs to "Settle" "beak-in" if there is there such a thing?or cut the rear bump stops to 1/4
Spring rates are near as stock and up to 7kg at final rate but it seems still firm, and near other lowering spring rates
F-Sport Springs
Front = 6.6kg/mm
Rear = 7.0kg/mm
If I change the springs whats the best in terms of comfortable ride and stock feel, even if it reduces cornering performance.
Many Thanks
Super Moderator
Any "performance" suspension is going to ride a little bit more stiff then factory regardless of all the reviews you read. From personal experience even though i have never owned them personally the F-sports had the best ride i had ever been on vs factory. H&R which i have owned were probably second. Next to doing that your only real other option that i can think of off the top of my head is to get a set of coils and do a custom spring rate setup.
As far as settling goes if they have been installed for 2 weeks they are more then settled. I personally have never seen settling take more then about 20 miles.
Discussion Starter #3 (Edited)
thanks!
install was great no squeaks or clunks its just the firmness of the ride, Is it the progressive nature of the springs? Because at good roads with a few dips and waves the ride is GREAT but at paved cemented roads its REALLY STIFF.
Thats why I'm thinking of
H-Tech
F - 6 kg/mm
R - 6.3/kgmm
or
Swift Springs which has the closest to stock
F - 4.6kg/mm
R - 5.2kg/mm
Or go the Coil-over Route with Tein Comfort Sport.
Or the F-sport shocks are making the ride stiff together with the F-Sport Spring because it is a more performance oriented setup?
I was thinking about swapping out my OEM suspension for an F-Sport suspension and I was told not to by my service advisor. He strongly recommended against it. From what I hear, the closest match to stock are the Swift Springs.
