Hey guys,
First time seller and I am hoping I can get some local guys to buy the Rockford stuff since it weighs a ton. Had this set up in My Evo and now I have an IS with a sterio which I will be selling soon and my 19" Volks.
I am gonna start with this and see what happens,
Thanks for the space
Lexus Grill....45 bucks Shipped
12" Rockford Sub in box....$125 8"x21"x14"
Rockford P8004 Amp...$250
(Details from Rockford)
4-channel car amplifier
100 watts RMS x 4 at 4 ohms (200 watts RMS x 4 at 2 ohms)
400 watts RMS x 2 at 4 ohms (4-ohm stable in bridged mode)
2-, 3-, or 4-channel output
CEA-2006 compliant
Tri-way capable (Tri-Way Crossover required)
requires a 4-gauge wiring kit and a 150-amp fuse — wiring and hardware not included with amplifier
MOSFET power supplies and output stages
MEHSA transfers heat efficiently from the MOSFET devices to the heat sink for high performance
TOPAZ eliminates ground loop noise
trans-ANA circuitry keeps preamp signal clean
NOMAD "intelligent" protection circuitry
preamp inputs and outputs
variable high-pass/low-pass crossover (40-400 Hz, 12 dB/octave)
variable Punch Bass boost (0-18 dB at 45 Hz) with remote
17-5/8"W x 2-3/8"H x 11-1/4"D
CEA-2006 compliant
