1 - 8 of 8 Posts
i jst installed the toyomoto gen 2 header and there y-pipe, mated to the factory b pipe and that mated to the hks dragger 2.
im pretty sure i have a leak somewhere. im getting a hissing sound under hard acceleration. i used the gasket from toyomoto but it was a little bit distorted. will tat cause a leak?
will using the rtv hightemp silicon sealent help solve the leak?
Am I Hype-R???
it's a possibility...
maybe temp fix but i wouldn't trust it longterm...
best thing to do is to get the car on a lift and inspect each connection to find the leak...then get a new gasket...
take it to a muffler shop and have them check it out. If you cant get a gasket to rid of the leak or if the parts don't fit right, have them cut it and weld it.
i can tell u that the leak will most likely come from header to y pipe connection. y pipe to stock B pipe, u can use OEM crush gaskets as well as stock B pipe to dragger.
anyone know where i can get the gasket between the header and y pipe for the toyomoto header?
PM nless_dream (the guy that posted right above you). Check out the link in his sig. I have a gasket from him, and it took care of the leak I had.
What intake you have? I have in SRT and that thing makes my car hiss not the exhaust.
1 - 8 of 8 Posts
