Ok here is some information that im sick of pasting into threads everytime someone is worried about Tickets for EXHAUSTS or Warranty issues and being affraid of modding a car.
Here is some info I have picked up over the years from being in the parts business.
1. If you replace a part with something aftermarket and that part causes a stock part to break, then the dealer can void the warranty on that part only and charge parts and labor to replace or fix.
2. Just because you lower the car doesn't mean your whole suspension aspect of warranty is gone..
3. Modding your car is a right, below I will attach some documents and a phone number that proves this as correct.
As for putting an aftermarket exhaust on and getting a ticket for it.
1. You are allowed to put on exhausts.
2. Why are there muffler shops? Ever gone into a muffler shop and re-ordered a stock exhaust? How many thousands of people have aftermarket exhausts on their cars who DON'T even modify their cars?
3. IN CA there aren't any legal DB stations for testing since the mid 70s, db tickets are often won because of this fact. How can the officer prove your current DB level? Judges take this info into consideration when making their judgement.
Im sure I have left little bits out, if you have questions Just ask.
HERE IS THE LAWS ON EXHAUSTS
______________________________________________________________
CALI CHP LAWS
TAKE THIS TO COURT CALI GUYS
kinda long!!!
CHP BULLETIN NO. 98-100
EXCESSIVE NOISE ENFORCEMENT
PASSENGER VEHICLES, LIGHT TRUCKS AND MOTORCYCLES
The California Highway Patrol (
CHP), Commercial Vehicle Section (CVS), has received many inquiries about excessive noise emitted by passenger vehicles, light trucks and motorcycles. Enforcement personnel and the public have inquired regarding enforcement of the Vehicle Code (VC) sections pertaining to excessive noise emitted by these vehicles.
Excessive noise is primarily a nuisance issue rathers than a safety concern, and determination of excessive noise is subjective. For this reason, enforcement personnel are to exercise sound professional judgment in making a determination of violation. The following guidelines and attached question and answer sheet (Attachment A) provide guidance to enforcement personnel regarding appropriate enforcement procedures.
Enforcement Guidelines
The only drivers who should be cited are those whose vehicles:
1) are not equipped with a muffler;
2) clearly emit an offensive, harsh, excessive noise, or,
3) have a clearly defective exhaust system (holes, leaks, etc.).
Clearing Citations
When clearing excessive noise citations issued by the
CHP or allied agencies, personnel are to consider exhaust systems in compliance if they incorporate a reasonably effective muffler, do not emit an offensive, harsh, excessive noise, and appear to be in good repair.
ATTACHMENT A
Q1 Doesn't the VC require a muffler on every vehicle?
Yes. Section 27150 VC requires that every motor vehicle subject to registration be equipped with an adequate muffler. There are no exceptions - all vehicles must be equipped with a muffler, as defined in Section 425 VC. A turbocharger is not considered a muffler.
Q2 Aren't all exhaust system modifications prohibited?
No. Section 27151 VC prohibits the modification of the exhaust system to amplify or increase the noise emitted by the vehicle, making the vehicle not in compliance with Section 27150 VC or exceeding the noise limits established in Sections 27201-27206 VC. Section 27151 VC does not prohibit all modifications to an exhaust system. It also does not prohibit all modifications that increase the noise level of the exhaust system over that of the original, factory-installed exhaust system (as it did until 1980). It only prohibits modifications that result in a noise level higher than those specified in Sections 27201-27206 VC. Accurately determining compliance with Sections 27201-27206 VC for enforcement purposes is generally impractical. Enforcement personnel must make an informed professional evaluation to detem-iine if excessive noise statutes are being violated.
Q3 Do I have to actually listen to a vehicle to cite it for a violation of either Section 27150 or 27151?
Yes. Drivers of vehicles should not be cited for violation of either Section 27150 or 27151 VC unless the officer has personally listened to the vehicle in operation. T'his can be either under actual driving conditions or with the vehicle stationary and the engine running. Even if the officer has inspected the exhaust system and does not see a muffler present, the officer should listen to the vehicle. The purpose of this is to be sure that the exhaust system does not incorporate internally baffled pipes or other components that meet the definition of a muffler. There are no specifications which state required configurations or minimum dimensions for mufflers. A vehicle that does not visually appear to be equipped with a muffler, but does not emit excessive noise, should be deemed to comply with Sections 27150 and 27151 VC.
Q4 Does an aftermarket replacement or modified tailpipe or muffler tip constitute a violation of section 27151 VC?
No. Section 27151 VC prohibits the modification of exhaust systems to amplify or increase noise. The officer would have to establish that the modification increased the noise emitted by the vehicle by listening to the exhaust. In general, exhaust system piping, tubing, fittings, cosmetic tips or other passive devices placed behind the muffler have minimal impact on exhaust system sound levels.
Q5 Since Section 27150 requires that the muffler prevent excessive and unusual noise, can the driver of a vehicle be cited for violation of Section 27150 if it emits a sound different than the original factory installed muffler?
No. The prohibition against unusual noise refers to noises that are unusual for motor vehicles. Noise that may be unusual for a particular make or model of vehicle, but which is not necessarily unusual for other motor vehicles, should not be considered in violation, provided the noise is not excessive.
Q6 Aren't all modified exhaust systems unlawful under pollution control laws?
No. Current pollution control laws regarding aftermarket exhaust systems are quite complex, but do permit the installation of a variety of aftermarket and "exempt" systems. Due to the complexity of modem pollution control systems and the laws governing them, the
CHP does not provide technical training in this area. Enforcement of pollution control laws is the responsibility of the Bureau of Automotive Repair through the "Smog Check" program.
Q7 What are the noise levels specified in Sections 27201-27206 VC? Can these be used to cite loud vehicles?
No. Section 27200 VC prohibits the sale of new motor vehicles that exceed the noise limits specified in these Sections. The specified noise limits (80 dB(A) (decibels) for all new cars, pickup trucks, vans and motorcycles apply only to new motor vehicles, under full throttle acceleration tests, measured 50 feet from the test vehicle, as specified in Sections 1040-1044, 1046 and 1047, Title 13, California Code of Regulations (13 CCR). These noise levels and the specified test methods apply to manufacturers and new car dealers only, for new vehicle certification purposes, and may not be used for enforcement purposes against vehicles being operated on public roadways. The
CHP is not aware of any significant violation of Section 27200 VC by vehicle manufacturers or dealers.
Q8 What are the noise levels specified in Sections 23130 and 23130.5 VC and how can they be enforced?
Sections 23130 and 23130.5 VC specify noise standards for vehicles operating on the highway (in-use vehicles), and are intended for use in actual traffic conditions. The limits of Section 23130 apply under all conditions of grade, load, acceleration and deceleration. The lower limits of Section 23130.5 apply only to relatively level roadways and under conditions of relatively constant speed. They specifically do not apply to areas of congested traffic that require noticeable acceleration or deceleration, or within 200 feet of an official traffic control device or change in grade. Although these sections were intended for use in actual traffic conditions, the complexities of noise testing require the testing be conducted in a relatively large open area free of other vehicles and large sound-reflecting objects. This makes in-use vehicle noise testing in most developed areas impractical, where noise complaints are most likely to occur. The
CHP does not currently provide either the instrumentation or training necessary to conduct vehicle noise testing. Enforcement using Section 27150 or 27151 VC is usually more appropriate and effective.
Q9 What is the exhaust noise test specified in 13 CCR? Can this be used for enforcement?
Sections 1030-1036, 13 CCR, were intended to be used by Licensed Muffler Certification Stations as a means of deten-nining if an exhaust system met the requirements of the Muffler Certification Program (when those programs were operational). They specify testing procedures for motor vehicle exhaust noise alone (as opposed to total vehicle noise). This procedure specifies a limit of 95 dB(A) measured 20 inches from the exhaust pipe outlet with the engine operating in neutral, typically at a speed of 3000-5000 rpm. (For comparison, a modem rotary lawn mower with a 5-horsepower Briggs & Stratton engine typically emits approximately 93 dB(A) at the same distance at full speed under no load.) It applies only to passenger vehicles. It does not apply to motorcycles or to vehicles over 6000 pounds gross weight.
Q10 Can this test be used in enforcement?
Not readily. Although much simpler than the test methods specified in Sections 23130 and 23130.5 VC, this test method still requires some technical expertise and a means to determine both the speed (rpm) of the engine under test (tachometer) and the rpm at which maximum horsepower of the engine is developed (information which may not always be readily available), as well as a sound level meter. It is not intended for roadside noise testing. The
CHP does not currently provide either the instrumentation or training necessary to conduct exhaust noise testing. This test is useful, however, for determining if an aftermarket or performance exhaust system complies with VC requirements. It should be noted that the 95 dB(A) level, because it is intended as a simple "go-no-go" type of test, may permit exhaust noise somewhat higher dm those permitted under Sections 27201-27206 VC. An exhaust system that complies with the requirements of Section 1036(d)(1), 13 CCR, is deemed to comply with Sections 27150 and 27151VC.
Q11 What happened to the Muffler Certification and the Licensed Muffler Certification Station Programs?
Funding for both programs was terminated in 1979. There are currently no Official Muffler Certification Stations, no listing of certified mufflers and no formal mechanism in place to conduct objective vehicle or exhaust noise testing.
Q12 Can local authorities enact or enforce more strict ordinances regarding vehicle noise?
No. Section 21 VC makes the VC applicable and uniform throughout the state, and prohibits local authorities from enacting or enforcing any ordinance on the matters covered by the VC unless expressly authorized to do so. In-use vehicle noise is addressed in Sections 23130 and 23130.5 VC. There is no provision in the VC that permits local authorities to adopt additional noise limitations. Consequently, citations issued under such ordinances are invalid.
Q13 Some aftermarket exhaust systems include documentation that the system has been tested and found to meet the requirements of section 1036(d)(1), 13 CCR. Are those legal?
Tle
CHP does not have the resources to independently verify manufacturer's claims, but is aware that some aftermarket exhaust systems do meet the noise levels specified in Section 1036(d)(1), 13 CCR. An officer may consider such documentation in evaluating an exhaust system for excessive noise, both during the issuance of a citation and when clearing a citation pursuant to Section 40610(b) VC.
Q14 What type of enforcement action should be taken against vehicles emitting excessive noise?
Providing none of the disqualifying conditions listed in Section 40610(b) are present, the use of the
CHP 281, "Notice to Correct" or checking the Dismissable Violation "Yes" box on the CHP 215, "Notice to Appear (Arrest Citation)," would be appropriate for these violations.
_________________________________________________________________
AND HERE IS WARRANTY INFORMATION DETAILS
You have the RIGHT to buy high-quality, reliable aftermarket accessory, performance and replacement parts – an affordable and convenient alternative to vehicle maker’s parts.
You have the RIGHT to use high-quality aftermarket parts and know that your new car warranty claims will be honored. In fact, your dealer may not reject warranty claims simply because an aftermarket part is present. A warranty denial in such circumstances may be proper only if an aftermarket part caused the failure being claimed.
You have the RIGHT to patronize independent retail stores for vehicle parts and installation. The U.S. aftermarket offers the world’s finest selection of performance and replacement parts, accessories and styling options. These aftermarket products satisfy the most discriminating customers seeking personalized vehicles for today’s lifestyle
and here is some other good stuff
Some motor vehicle dealers and manufacturers are telling customers that the factory warranty on their motor vehicles is "void," if aftermarket parts or accessories are installed on their vehicles. This is incorrect. DONMAR would like to refer you to the federal Consumer Product Warranties law, under the Magnuson-Moss Warranty Act, which states, in part, in Title 15, United States Code, Section 2302, subdivision (c) that:
"No warrantor of a consumer product may condition his written or implied warranty of such product on the consumer's using, in connection with such product, any article or service (other than article or service provided without charge under the terms of the warranty) which is identified by brand, trade, or corporate name; except that the prohibition of this subsection may be waived by the [Federal Trade] Commission if –
the warrantor satisfies the Commission that the warranted product will function properly only if the article or service so identified is used in connection with the warranted product, and
the Commission finds that such a waiver is in the public interest. The Commission shall identify in the Federal Register, and permit public comment on, all applications for waiver of the prohibition of this subsection, and shall publish in the Federal Register its disposition of any such application, including the reasons therefor."
Under this federal statute, a manufacturer, who issues a warranty on your motor vehicle, is prohibited from requiring you to use a particular brand of product, unless such item is provided, free of charge, under your warranty or unless the Federal Trade Commission (FTC) waives this prohibition against the manufacturer. DONMAR is unaware of any exemption or waiver granted by the FTC to any motor vehicle manufacturer, which pertains to parts, accessories or styling products.
DONMAR considers any claim to void your factory warranty, or the actual voiding of your factory warranty, solely for the installation of a DONMAR product or other aftermarket accessory, to be a violation of federal law. We reccomend that you ask your dealer to provide a written record of the warranty denial, including specific reasons, if warranty is denied under the following circumstances:
A motor vehicle dealer fails to provide warranty coverage on an unrelated factory part, and refuses to "demonstrate" [as federal law requires] that an installed aftermarket product caused the failure for which warranty coverage has been denied.
A motor vehicle a manufacturer refuses to honor, authorize or cover warranty repairs on your vehicle, merely because you have an aftermarket product installed.
A motor vehicle dealer or representative of the motor vehicle manufacturer advises you, prior to your purchase, that the installation of aftermarket parts or accessories will void your vehicle warranty.
The Specialty Equipment Market Association (
SEMA) monitors problems associated with warranty claims to ensure that vehicle dealers are not misrepresenting the law. If you believe legitimate factory warranty coverage has been unfairly denied due to presence or installation of aftermarket parts or accessories, contact SEMA online at SEMA.org || StartPage || Specialty Equipment Market Association SEMA, or call 909/396-0289. SEMA will contact the dealership and manufacturer to advise them of the law and request that they clarify their position relative to the installed aftermarket parts or accessories.
In addition to any informal action
SEMA may take, you should consult an attorney and various state and federal agencies, who may be able to assist you in protecting and enforcing your warranty rights, if you encounter a motor vehicle dealer’s or manufacturer’s refusal to honor your motor vehicle warranty.
If the failure to honor a warranty claim involves the new vehicle warranty, and it appears that the dealer improperly denied the claim, file a complaint with the Federal Trade Commission (FTC) online at Federal Trade Commission - Home, or call 202/326-3128.
Yes this is a long read, don't be lazy....
D
The problem with the legal side of it is, it is all left up to interpretation, and when that is the case, you lose every time as the judge will almost always side the the officer.
"The only drivers who should be cited are those whose vehicles:
2) clearly emit an offensive, harsh, excessive noise, or, "
Who makes that determination? The officer. Bottom line, if he wants to be a jerk, he can. If he wants to be cool, he can. When it comes to the California Vehicle Code, there are to many laws left up to interpretation like that.
this print out and someone who knows how to show up to coart with broad shoulders and isn't an ass, can win easy.
I should know, won 2x on exhaust noise in CA.
d
I never had this exact printout, but had most of the information, represented the information and myself in respectable manner, still lost both times I went to court on this, so apparently I'm an ass. I will be retaining your services for representation next time. :)
Thank you, i make constant visits to San Diego yearly.
D
