1 - 10 of 10 Posts
Hey Guys,
Where should I connect the vacuum tube from the EVAP system to the intake airbox on the lower side? Should i connect it before or after the turbo?
Any help is appreciated!
Um don't we not have EGR? Did you do a GTE swap or something?
i went with vvti ge - t. anyway i looked at the vacuum diagram and it says there's a EGR system. A hard line comes from the passenger side connected to a valve, and then a vacuum tube goes into the intake pipe before the MAF. Where should I place that vacuum tube (if not delete) it?
I'm not 100% sure if it's EGR, but since im' using an AEM intake pipe as one of my intercooling pipes, I don't know where I shoudl route that vacuum tube.
uh neither the post 98 ge or the gte have EGR, I believe.
not sure what you're referring to since I couldn't find any EGR valve or anything similar to it on my repair manual
I scanned it and uploaded the only thing I seemed to find...
Holy cow that GTE vaccum hose diagram is a nightmare lol. Good thing I went with VVTi and single turbo ;)
Discussion Starter #9
i didn't do an aristo swap. sorry that i got evap confused with EGR. After doing more research, vvti's do not have EGR.
+1 for the diagrams...and holy crap!
edit: so where should i route the EVAP tube that was originally connected to the stock airbox to? before or after the turbo?
Evap requires vacuum. Plumb it to the intake side of the turbo. Some people don't bother plumbing this at all and just let it hang. My pref is to plumb it to vacuum.
Reactions: ElitistK
1 - 10 of 10 Posts
