1 - 15 of 15 Posts
2004 Lexus IS300 5 speed, around 144k-145k miles. I was chilling in my car for only like 5 minutes when my Check Engine Light Came on and TRAC started blinking. I scanned the ecu with a reader and came back with these codes. My older 2002 lexus is300 had a evap issue before but it was only giving me a p0440 code. Anyways, what are your guys opinion on what I should do? I was told to replace the EVAP canister vent solenoid. But idk :confused::confused::confused:
Start with the easy stuff. I would replace the gas cap with another OEM. Then inspect your vacuum lines under the hood. Blank the codes and do a drive cycle.
^What he said. I've been getting some EVAP codes recently, 441,442 and 446 as well. I replaced the gas cap which had some cracks and splits on the rubber o-ring, I replaced some torn hoses going the VSV under the hood and the codes still came back. My VSV tested bad (no continuity between the pins) so I have one on order. The VSV is what fixed my EVAP codes with my last IS so I'm thinking this is the issue.
2004 Lexus IS300 5 speed, around 144k-145k miles. I was chilling in my car for only like 5 minutes when my Check Engine Light Came on and TRAC started blinking. I scanned the ecu with a reader and came back with these codes. My older 2002 lexus is300 had a evap issue before but it was only giving me a p0440 code. Anyways, what are your guys opinion on what I should do? I was told to replace the EVAP canister vent solenoid. But idk <img src="http://my.is/forums/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" /><img src="http://my.is/forums/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" /><img src="http://my.is/forums/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" />
Thanks guys! I’ll start off with the gas cap and look for any bad hoses. Wish me luck !
The manual has a complete trouble-shooting procedure. I'd probably start there. The whole point of the codes is to point you in the right direction so you don't end up shot-gunning parts at the car in the hope it fixes it.
check your evap lines for cracks, and if access to a smoke machine use that.
. i replaced this from the video and a evap piece by the intake to fix mine. ive found that its not always a vsv issue or gas tank issue with these cars.
Discussion Starter #13
did that fix it ?
Hey, late reply, But about a month ago i deleted the code and tightened my gas cap and the light came back til now. So upon inspection from the engine bay I noticed that this plug to this evap piece was disconnected. Could this be the reason why Im getting these codes? I dont see any cracks from the vacuum lines. Just need some second thoughts lol
1 - 15 of 15 Posts
