I did a search and all i could find was about amps. I just hooked up my fm modulator and it sounds great except for the engine noise. what do i need to do to eliminate it?
Good grounding is the key. That usually helps. It is best when all of the componentes use the same grounding point. Last time I installed MP3 changer with FM modulator, I used amp's grounding.
What is your source? It may be where the problem originates.
Useless
