the rear eibach anti-sway bar has 3 holes in it to let you choose the stiffness. what setting are you guys using? i don't have the install instructions but i'm assuming that the inner one is the stiffest? does anyone have instructions they can send me?
thanks! chris
IS JOE said:
the inner one should be the stiffest.
yup, the inner one is the stiffest setting. i've got mine on the medium setting, but i'm contemplating changing it to the stiffest setting...
well, they are installed! took me a few hours with the help of my father-in-law but i think that we did a pretty good job (i might have the dealer check my work though next time i bring it in). i used the stiffest setting and i definitely feel a difference. the back-end definitely feels different..a lot tighter feeling on the turns. can't tell as much on the front but that is probably to be expected. it's amazing how much heavier the front pro-kit sway is compared to the stock sway so it must be doing something up there. :p
thanks again for the help guys.
chris
one step closer to being l-tuned!!!
