Das,
Okay, here we go, in its simplest form:
Air density
0.076 psi @ 60°F
0.068 psi @ 120°F
So the air is 10% less dense @ 120°F, requiring 10% less horsepower to do the same speed.
For the same example, the SAE correction factor shows a HP drop of 5% from 60°F to 120°F.
From that, you can conlude that you actually have a 5% power advantage over running in the lower temps.
I know it's an extreme example, but it's one that gives you a good idea of what really goes on.
I can't find all the hardcore math we did for one of our projects similar to this, but hopefully i can find them. I'd rather not derive it all again.
In our project we assumed runs from sea level, but i think SCCs example was just assuming that bot hruns occurred at the same altitude to keep everything consistent.
I'd dole out more rep if i could, good discussion!!!
Air density
0.076 psi @ 60°F
0.068 psi @ 120°F
