I jumpered the functions over on the emanagae PNP harness. The car seems to run fine without any hicups, its just at Idle it:The first question I have will be how you did the B1S1 connect to the B2S1.
-Are you sure you connected the that right, ie you used the right wire and tapped into the right wire at the ecu point (or on your emanage jumper)
If after double checking you got it right lets move to the second step.
- I am assuming you disconnected the o2 sensor plug and removed the sensor itself.
So now reconnect the sensor plug zip tie the sensor itself somewhere where it will not melt anything (dont hold it, it gets pretty hot). Now try starting the car again and see if it still idles the same way.
PS: I may be wrong but did you mention wanting to add the srt intake to your car?
