Just learned that if your "Trac Off" light flashes while engine is running and you have CEL then your ECU is in "Safe" Mode. Lowering the rev limiter to 3000 rpms, as to not let your engine detonate. Anyone ever heard of this? :-? :eek:
Chris
So now I know WTF is wrong with my car, now just got to get it fixed.
Need a new intake...
Threadlocker
borrow a local member's stock one for a while and see what other problems you have...
If I get the problems fixed, and reset the ECU shouldnt the "Safe mode" go away? Or is my ECU hosed.
Anyone here in the houston area willing to do this?
Chris
My guess would be if you disconnect the battery for 15 min, ECU will reset itself and exit the safe mode. However, if it detects the same settings that put it in the safe mode in the first place, it will go back to the safe mode.
