If i dont qualify to get the free ecu reflash, is $150 a reasonable price? It seems costly.
Bottom line is unless you're having some serious issues I don't think it's worth $150. That said I thought TSBs were always free.......ECU Reprogramming:
Covered under Technical Service Information Bulletin:
TSIB EG003-01
In the first batch of 2001 IS300's there existed a problem with the ECU / TRAC systems that created some very strange problems for the car. This is actually 2 separate issues; however they are more often than not referred to as a single issue.
The ECU reprogram update affects all IS300s whose VIN number is LOWER/BEFORE 10025186
the problem existing with the ECU was a slight delay during shifting between 2nd and 3rd gears as well as a downshift from 5th to 2nd. Drivers were experiencing jerky and lagged shifting patterns which made for a very uncomfortable driving experience. Drivers have reported smoother shifting since having this reprogrammed.
If your VIN qualifies you for this upgrade, please contact your local Lexus Dealership to schedule an upgrade. Please also be aware that due to a nationwide shortage of these chips that there is often a waiting list to have this done, so be patient.
It is also necessary to have all keys/spare keys present at time of reprogramming so that the keys may also be reprogrammed.
TRAC Reprogramming:
TSIB EG003-01
The TRAC ECU replacement affects all IS300s whose VIN number is LOWER/BEFORE 10029014
The problem existing with the TRAC was an overly sensitive sensor that would cause the TRAC to be enabled earlier than necessary and at the slightest of wheel spin, even on dry pavement. This caused a power lag during sharp cornering and sometimes on acceleration. The TRAC update requires a new TRAC unit for the computer and this modifies the sensitivity of the TRAC unit and its threshold determination of wheel spin. Drivers reported far less instances where TRAC was invoked after having this replaced.
They do have an expiration date for having it completed by for it to be free of charge.Here's the exact text of the TSB (Technical Service Bulletin)
I also think if you don't apply to the TSB then reflashing the ECU probably won't do anything.
If you have an 01 or 02 in the VIN range with less than 80k miles, you qualify (but may be cutting it close on the time frame).If i dont qualify to get the free ecu reflash, is $150 a reasonable price? It seems costly.![]()
i believe they told me 70k when i took mine in for the TSB. You shouldn't pay for the 150 not that much of a difference for the price.If you have an 01 or 02 in the VIN range with less than 80k miles, you qualify (but may be cutting it close on the time frame).
If you don't have an 01 or 02 in the VIN range, then you don't need it.
If you have an 01 or 02 in the VIN range with more than 80k miles, I would not pay $150 for it.
I had the TSIB done about a month ago and the only difference I can tell is the occasional hesitation at low RPMs is gone, which isn't worth $150 to me.
According to the TSIB, it's 8 yrs from the vehicle in service date or 80k, whichever comes first.i believe they told me 70k when i took mine in for the TSB. You shouldn't pay for the 150 not that much of a difference for the price.
got mine done with 81k on it for free. Printed off the TSB, didn't leave til they reflashed it for free, But it didn't do anything..it still hesitates once and awhile..sigh.
maybe it is time to clean my maf again. basing on the last two posts, its looks like the reflashing is not worth itReflash ECU recently had it done. It had problems shifting from 2nd to 3rd,did not do anything, but recently i clean the Mass Air Flow Sensor and throttle body with Intake Cleaner and the issue went away. Just be careful while cleaning the MAFS. Use the intake cleaner while blowing moderate air. Replace into intake and idle for five minutes and take it for a test drive.
Yea try it out it worked for me!!!!maybe it is time to clean my maf again. basing on the last two posts, its looks like the reflashing is not worth it![]()
I think diag alone is like $75 at my local dealer, so between that and the flash I'd definitely just get the flash.Then you pay diag? Perhaps ask if they could have someone drive it quick and if they think it will take care od it you will have it done but you dont want to pay diagnosis on the flash....
