hey everyone,
Been doing a ton of searching and reading I’m having a rly hard time finding an ecu for my auto transmission 03. Can anyone point me where to look?
Thanks
There is no aftermarket ecu capable of running your automatic... Not without some heavy reverse engineering on your part, anyway...
I did come across a fellow on another forum that claims to have an automatic IS300 up and running on a transmission controller he built himself after reverse-engineering the system. He doesn't share how he did it, nor does he offer them for sale.
So basically - you'll need to keep your Toyota ecu in place (and connected enough) that it can continue to issue correct commands to the transmission.
Neat! Was unaware of that.
FWIW: An electronically controlled automatic requires "calibration", so something like this is not a plug and play. It'll require considerable effort to act like you think it should.
Never said it was PNP. Hesse "PRO" in the description.
2001 E-Shift, NA-T, Standalone
Someone on a forum used a Dicktator Transmission Controller for his a650e swapped SC300.
