Hi all,
new to the community, recently purchased a 2007 is250 automatic with Nav but no ML.
Just wondering where the best place to tap into would be for the remote wire and for a line level input?
just looking to wire up a monoblock and 2 subs to the stock system.
Thanks!
Stock amp in the trunk on the right side. Lift up the plastic cover and you will find the amp. I did the install a couple of months ago but if I remember correctly, the remote wire is a small pink wire from the biggest harness. That orange wire is towards one side.
As for line level inputs, if you take the harness off from the stock sub (lift up the cover with your back seat out), you can just run additional wire off it and then hook it up to either LOC if required.
I connected my line out converter to the harness that connects to the stock amplifier. it was an easy 4-wire hook-up.
\/ Awesome \/
Hi all,
Thanks!
What type of setup are you putting in?
