i was wondering for all boost memebrs using e-manage what are your jumper settings.
as for supercharged guys running the 7th injector your settings will not work..i need the settings for any boost members using 6 550cc injectors thanx...
this is what i found over at prolexperformance
Pro Lex Performance Fuel and Timing Controller for 02-04 IS300
Rotary Switch Settings (remove cover to access):
sw1 = 6
sw2 = 2
sw3 = 5
Jumper Settings (when using sub injector CH-A):
jp1 1+2
jp2 2+3
jp3 1+2
jp4 none
jp5 1+2
jp6 1+2
jp7 1+2
i already set up the rotary switch that is fine but as for the jumpers this is the setting with the 7th injector i need the setting without the 7th injector since i am not using one
Podiatrist
i don't think jumper settings are related to injector setup.
i forget, but i think one jumper is different in 02+.
Dagixxerkid posted about this. I think jp3 is 2-3.
Try it.
Try it.
They are.
