Edit: does anyone know how to shrink images with the vb code? I don't know how so if anyone can tell me or a mod wants to shrink them for me, they're... a little large
Hey guys, just replaced my break pads and when I did it was just enough that my wheels wouldn't fit anymore. So I grinded down the caliper a bit, and decided I needed to paint them so they wouldn't rust.
Needless to say I couldn't way to order the G2 kit, so I figured I'd try out the duplicolor kit from my local pep boys. It was also only 14.95 so that was a plus as well.
The kit was similiar to the G2 kit, brush on, very thick paint, although it did not have an activator like the G2 kit, so you can take your time doing the wheels before the paint hardens up. Whether this has any ill effects is yet to be seen. It comes with a spray paint of caliper cleaner, some really crappy masking tape, and a small brush that can get in between pretty well.
Anyway, so I jacked up the front of the car on two stock jacks (I know, didn't have any jack stands), cleaned the calipers and started painting them. The fronts in particular I was worried about too thick of a layer of paint, since I had to grind the calipers anyway. So I put on four very thing layers of paint.
I waited two hours until putting the wheels back on, lowering the front, jacking up the rear and doing the same, although on the rear it was getting late so I did three thicker coats.
Right after finishing those I got a phone call and discovered I needed to leave in the morning to drive my roomate to surgery, you may have remembered that frantic post
Anyway, left after about 8-10 hours, drove an hour back, no problems at all.
Heres some pics of the new wheels and the calipers painted, still havn't put on any stickers yet, need some from flatline
Anyway I think it turned out pretty well and makes a good alternative if you don't want to get the G2 kit, becuase of price or local availability.
Let me know what you think.
