1 - 14 of 14 Posts
When i was installing the grill today, the plastic "screw" that hold the side of the grill fell into the engine bay and i was not able to take it out. Do you guys know how i can take it out or where i can get a new one?
are you able to see it?
get a long stick, put some sticky stuff on it, maybe tape, or blue tak(forgot what its called), and reach in...
its the plastic thing right?
Not Officially Back
cnilu said:
WhiteLex said:
Just take off your under panel underneath the car and it should fall right to the ground
how to take it off?
There are 14 10mm bolts that hold the underbody panel on... doesn't take too long to get off if you have a ratchet.
Good luck
use the stick with tack idea... if you tap the underpanel you should be able to find out where the screw is around. i've dropped a couple bolts down there, but i managed to get them out with a metal stick with a magnet at the end.
1 - 14 of 14 Posts
