1 - 9 of 9 Posts
Penetration Specialist
Hey guys...the money is kind of tight right now, so i'm thinking about skipping on the big brake kit for now and going with some upgraded drilled or slotted rotors and some pads.
Can you guys suggest a good setup and maybe some pictures of the rotors you have installed?
Also, would you suggest getting some SS brake lines? Thanks!
u liked my rotora's better though ;)
No brainer...www.iRotors.com
It would be wise to upgrade to SS lines and a HP pad. If you need to take a test drive in mine to feel the set up...just give me a call! :D
i was told the irotors rust quickly. the rotora's come painted already
yeah i contacted steve ganz...said he only has the fronts in stock... :-?
I may go with iRotors.
How about brake pads and stainless steel brake lines???
1 - 9 of 9 Posts
