· Registered
Does anyone have problem with their door locks jammed,so you can not open the door handle??? This happened to me three times already? I have tried to lock and unlock again with both the remote and the actual car key..It still won't open..But you can hear and see the lock (orange color part) unlocking the door??? Help !!!
· Registered
Spray the Door Latch with some WD-40. Mine usedto be kinda tough to open when you pull on the handle. after the lube, it is smooth as the day i bought it. grease must have worm off inside the door jambs from washing and drying car. Good Luck.
· Premium Member
wd40 will work, if not to the dealer it goes!
