1 - 11 of 11 Posts
I am planning to get a SRT stage 2. Does anyone know where I can get it install and tuned? (with in the Bay area) And how much is the labor going to be?
Penetration Specialist
The piggy back unit comes pretuned. All you need to find is a reliable install shop that can do basic engine work/installs.
Srt2
Hey Wino_II how is your SRT stage 2 going? How do you feel about it? Is it reliable? What gauages did you put on? Is it require ir better to change it to performance clutch? How fast does it run in 1/4 mile?
13s_is300 said:
good shops include bozz and modified toys.
How do you know they are good?
I would do lots of searching before u choose a shop
Sacramento at Dynamic would be ur best bet, i think they are the shop who did the TOYOMOTO STAGE 2
David
David
I know Bozz installs turbo kits on WRX's, and Modified Toys did a GTE swap on an IS300. They seem to be qualified to do the work but i would call them and find out. Motorsports Dynamics did the Toyomoto install, but they charge an arm and a leg.
Bozz is good, im not sure about Toys, im sure someone here can post on them.... Something about an AE86 project.
David
those wrx with turbos and is300 owners going turbos in the bay must have a lot of money and time considering that they will need to take it off during the smog test day :crazy:
David
i was giving my suggestions for good shops. Bozz has done work on my car and i was very satisfied. i olnly tok my car there because i did my homework, and i would take it back there. Modified toys is almost finished with th gte swap as of wen. so in my book if they can swap a gte in they can install a turbo. again this is only my opinion based on my homework.
1 - 11 of 11 Posts
