I’m getting a weird popping sound from the front end when turning and was checking the front don’t suspension and saw these lower castor arm bushings that look like they arm popping out, doesn’t seem like any play but does this look right?
Thanks in advance)
I cant see the rubber center in those photos so hard to say if its good or not for sure
However i am pretty sure i could see it twisting around between the center and the arm on mine when it is holding together, those "look" like the arm may have moved up and down and contacted the body and brace, in which case they are no good.
133663
133664
133665
Thnks! I checked again and there is a small loose piece of rubber that can be pulled out from inside the bushing
Sounds like the bushes are broken, time to replace the bushings/arms. The OEM ones are solid on 2 sides and a gap on 2 sides to alow some movement, you shouldnt be able to pull any of it out.
Popping noises are usually lower ball joints. I'd replace those asap, as the ones on these cars don't last (especially if your car is lowered). And while you're in there get the Figs No. 2 arm bushing to fix the issue with your control arm bushing, it looks deteriorated from age.
