Do I need this tool to remove the crank pulley? I had a similar one for my civic and it made a huge difference when trying to change the timing belt.
i believe that tool is to stop the crank from turning, so you can loosen the bolt.
if you have the rad removed you can use an impact wrench to remove the bolt.
ok so i do need it, seeing as i don't have air tools. its 75 bucks, and the one for my civic was 25, exactly the same tool :p
