This is for the Bank 2 Sensor 2
I tried to make this as simple as possible... Enjoy!!
Unbolt all 4 bolts holding down the seat
Remove the plastic molding and lift up the carpet a little
When you take the seat out make sure you unclip the wires for the power seats that are under the seat. For air bag connections disconnect the battery and wait at least 90 seconds before disconnecting the SRS yellow connector.
Lift the carpet up enough to see the harness for the O2 sensor. You will need to unclip this. You can also see where the wire leads to under the car.
You will need to jack up the car to get to the sensor. Once you do that locate the 02 sensor and remove it.
Once I removed the sensor I re-scanned just to double check things and as you can see their is a 0.000v for the oxygen sensor 2 bank 2.
Now you need to wire the new sensor onto the harness. So make sure you match up the right wires
I connected the 2 Black to the 2 White...
1 White to the 1 Grey...
1 Blue to the 1 Black...
After you have the new sensor wired up just screw it back in (dont forget to add antisease on the thread of the sensor) and reconnect the harness that goes under the seat
I re-scanned to make sure the sensor is working. The pic is a little blurry but you can now see a value for oxygen sensor 2 bank 2
Now your all set just clip the carpet back in and put your seat back.
