Well my alternator went out so I had to replace it. I have a 2004 IS300 sedan. I haven't saw any DIY on it so I decided to make one myself. I lack the my tools list that I used for this because I did this in a rush I had work later that day so I needed my car. So here we go.
Tools:
14mm socket
12mm wrench
10mm socket
extension
6mm female Allen key
Jack stand and Jack
and screw driver depending on what Intake you have.
First off disconnect your battery (if you battery is dead then this is a good time to charge it either at home if you have a battery charger or take it to autozone its free.) and then take out your intake for more room to work on, also your under body cover. Jack up the pass front side or the whole front of the car up, your choice. Also place bricks or stoppers behind you back tires so the car doesn't rock back and forth. E-brake up and check to make sure your car is secure by shaking it. Safety first.
Then remove the accessory belt by pulling down the tension belt. As seen in the picture. Do not try to remove your alternator with the belt on. There is too much tension on the alternator and you might strip out the threads on the bolts that's holding the alternator. (I did this before on my old car.) As seen in the picture.
After that you can unplug the alternator and remove the top bolt right next to it as seen in the picture.
Then on the bottom shot of the alternator you can see the bottom bolt. Once you take off the nut you can use an Allen key (female end) and take the bolt/stud off all together. This makes removing the alternator a lot easier. If you don't take off the stud then you can remove the radiator fan by removing your top radiator hose and I believe 6X 10mm bolts holding it on to the radiator itself. Then you have enough clearance to remove the alternator. Just a couple of extra steps.
This is what the bottom alternator bolt looks when its off.
On the alternator when everything is off.
The only thing you need to swap out is the bracket from the old to new alternator.
Reverse the process and make sure the accessory belt is on correctly. This shouldn't mess with any of the tension on the belt if installed correctly. Cross your finger and hope your car start lol mine didn't the first time.
My issue was that the bad alternator messed up my battery. A couple of cells died in the battery. When the car was jumped it was reading 14.4volts and with the car off it stayed pretty constant at 11.6volts after 5min of rest. My battery was only 1.5 years old so I didn't suspect my battery at all. The alternator was bad either way. Under crank it dropped a low 4volts. That's a no no. Took it in to autozone since there was a 3 year warranty and everything was good afterwards. Just wondering if anyone hears a whining sound from their alternator on other is300. I am having that issue if anyone can give me their input on the sound. thanks. I hope this can help anyone looking to change out their alternator. GL.
Tools:
14mm socket
12mm wrench
10mm socket
extension
Jack stand and Jack
