htats not entirely true, i konw some of the older subarus, there's a fuse you pull out that makes the rear disengage, so basically you have a FWD subaru. not sure if they still have that on the newer models, but back then I believe they did it for emissions testing purposes and waht not.It's not "part time". There's never a time that 0% power is sent to the front wheels. Norm is, I think, 30%.
You cannont turn off the AWD. I don't think there's ANY car, truck or SUV, which has a "full time AWD" system, where you can de-activate it. Otherwise, it wouldn't be full time.
You're thinking of the Nissan GT-R harhar.i thot the awd in the is250 only kicks in when traction is lost in the fornt tire
+rep, you are correcthtats not entirely true, i konw some of the older subarus, there's a fuse you pull out that makes the rear disengage, so basically you have a FWD subaru. not sure if they still have that on the newer models, but back then I believe they did it for emissions testing purposes and waht not.
so thats atleast one "full time awd" car that can be disengaged and I;m sure there are others out htere than can be done, not sure about the IS250 though.
Ok--but that's a "hack". You can't "use the AWD when you wish", as the OP asked, if you have to reach under the dash and re-insert the fuse.htats not entirely true, i konw some of the older subarus, there's a fuse you pull out that makes the rear disengage, so basically you have a FWD subaru. not sure if they still have that on the newer models, but back then I believe they did it for emissions testing purposes and waht not.
whether it is a "hack" or not is impertinent to what you stated earlier.Ok--but that's a "hack". You can't "use the AWD when you wish", as the OP asked, if you have to reach under the dash and re-insert the fuse.
You "thot" wrong. Learn some english too while you are learning about the car.i thot the awd in the is250 only kicks in when traction is lost in the fornt tire
Get a G35/37x. That's puts all power to the rear wheels until AWD is needed (as opposed to 70%).becuz i saw on drivingtv.ca the woman said the awd remains a rwd bias until front traction is lost
so i was wondering if theres a way to shut down the front and only use RWD only wen desired
LoooolYou "thot" wrong. Learn some english too while you are learning about the car.
Really old dead thread 2008Looool
really Iliked your answer man
even if it was from the civil war, your response made me laugh and I wanted to share with you even if you were dead .Really old dead thread 2008
