What size bulbs are the DRL? Can you replace them with superwhites....the current bulbs look dingy in color.
The size is 9005. From what I've read, the DRL and the high beams utilize the same physical bulb. However, the DRL run it at 50% or something while the high beams kick the bulb to full power.
While I haven't done it myself, it looks fairly simply. Twist the bulb and pull it out. Piece of cake
They still won't be really hyper white because they are only working at half capacity. Do the DRL mod to get the hyper white colour out of the bulb, do a search for the mod.
