If i install a screen in the tray area, can i install a JDM dash tray after? Or should i do it before the screen goes in? The screen is most likely going to be removable. Thanks
if I understand the question correctly......
you are going to want o put the JDM tray in first, and figure which part you will have to mod on it to make the screen fit inside the tray with the door open.
if I misunderstood your question..... then you will have to reword your question, because you are making no sense there bud. :D
lol, thanks. i'll put the JDM tray in first. Sorry for the confusion, brain is pretty much dead right now. :)
