Those are called neo-wedge bulbs. I believe that those two are the 4mm ones. Just call around and ask if they carry neo-wedge bulbs. If not, your best bet is online, or the dealer if you need them asap.
Great. I assume they are white? Is it the label/icon of the switch that is orange or is the bulb emitting orange/red and the label/icon is white?
All of those bulbs are normal incandescent bulbs with a colored sleeve on them. The sleeve is some type of rubber material.
You could get lucky and find them at RadioShack. I found some at mine a while ago. Just need to take old bulb off plastic base and install new bulb.
