1 - 10 of 10 Posts
welp im all stock except my intake. had a shop give me and extra k&n carb sticker for it and turns out it was for the truck intake -_-. so im jewed now. should i just replace it with my stock one orrrr try to get ahold of another carb sticker? damn srt chip that i dont know how to remove thanks to my poor solder skills
If u do have a K&N intake u can take a pic of the intake on your car and contact K&N send them pic and they should send u a new sticker... On the SRT chip is a little tricky ur best off getting ur hands on a stock ecu... If ur not far from San bernardino I may be able to help u
it isnt complicated to remove the srt chip its just two solder wires. problem is i dont trust myself to do it
I can remove with no problem ... Easier option is my car is currently down and mine is a 5 SPd I'd be down to roll with u and let u borrow my ecu just offering I know smog is a bastard lol
thanks alot for the offer man ill keep it in mind. the shop said to just try get the correct carb number sticker and ill be fine. so im searching
Kool well good luck dude... I still got to pass smog to ugh but in the middle of rebuilding my motor
If you fail due to the srt chip, let me know. I will remove it then put it back for you, or we can come up with a switch to turn it on and off in the cab
1 - 10 of 10 Posts
