When I went to go put a cd in it starts making weird nioses so I hit the eject button to get the cd out and it jammed on me. :pissed: So now I have a cd stuck in the #1 slot. It doesn't show there being one in there and I can load another cd into the #1 slot it will only play for 3 second intervals and then skip.The other 5 cd's play like normal. So Iguess I'm gunna be taking a trip to the dealer to see what they can do. Hopefully it'll be covered under warrenty seeing as how I'm the second owner and didn't purchase it from a Lexus dealer. Sorry I just had to vent.
it will be covered under warranty... if it's a good dealer, or if you have a good relation with the service rep, they will replcae your head unit... if not, they will take care the problem for ya....
good luck!!!
Before you go, put some masking tape on the dash dash around the CD changer. That will insure that you end up with scratch-less dash.
BTW, if you can take that unit out yourself, you can fix it.
Thanks for reminding me about the tape I totaly forgot about that. I'm just gunna take it to the dealer I already have to make a trip there from new washer nozzles to put on my carbon hood. Thanks for the help.
No problem. 8)
